biomedtechguy
Accelerati Rapidus Maximus
- 9:11 PM
- Mar 28, 2014
- South Louisiana
"Regulars" on this Racers Forum have been so helpful and patient with my posts here. I realize most all of you are far more hard core than I am, but when I have improved performance questions or comments this forum has been great, and I greatly appreciate it!!
So I want to share these race related upgraded parts that I have on the way for my wife's 65 GTO rear suspension and to compliment the high performance aftermarket and tweaked factory original parts, like ported 6777 Pontiac heads 421 TriPower lurking under the hood.
I have a highly optioned 9" Ford based Quick Performance rear axle assembly being built, so I got these suspension parts to install since the rear axle is being replaced.
Bracket that ties the upper and lower control arm pivot points/body mounts together:
Pic of one connecting point for them:
Horizontal rear shock tower brace
Upper adjustable control arms
Lower lift bars, brackets deleted because Quick Performance is building in the multi position bracket into the rear housing. I don't quite understand how they work, so maybe y'all can help me understand, but they induce greater downward force on the rear tires for better traction:
Any input on my question about how these lower arms with their flexible mounting helps traction is appreciated!
Here's what UMI says:
"Lift bars work with axle torque to load the chassis of the car, forcing the rear wheels downward pushing the tires into the ground resulting in harder launches and improved 60-foot times. The UMI lift bars are designed to improve traction and reduce unwanted wheel hop."
