1967coronet440
I agree with 747, you need to pull the pump and inspect. Something is really wrong somewhere I’d put my money on the pump right now.
, maybe the shroud restricting it but I doubt that as well. A simple test would be to just take the shroud and all off and go for a spin avoiding any traffic or slow speeds, if it still gets hot with zero restriction at cruising speed you've eliminated the fan/shroud.I can not exactly tell you what heads they are, we wasnt build the engine. All i know is that its a 400ciSo those are just the heat crossover for carb heat. Not coolant and probably good they are blocked anyways. What heads are on the motor? I recall there being some late ‘70s motor home engine heads that take special head gaskets. Or I’m imagining reading that somewhere
No thermostat is defently the right side up.Is the thermostat upside down? I have seen that.
Overall sounds like a problem in the block, something blocking proper flow. That, and possibly generating way too much friction/heat to begin with. Piston size/rings/oiling?
