Mike Gaines
- 10:42 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Well guys...I found the limit of performance of my 66 Coronet this last weekend at the California Hot Rod ReUnion. At this race I selected the 10.25 INDEX and ran right on it for 2 days. Although I did make it to the SEMI ROUND in the Nostalgia/AFX class I got beat even running just .003 off my index (10.253 on my 10.250 Index).
But...here is the report of my quest to get a 9.999 time slip...
1) I first ran my 505" motor 3 years ago (10/18/2015) and recorded a best of [email protected] at that outing.
2) Over the last 3 years I have been upgrading almost everything on the car to go quicker...and it has worked...incrementally along the way.
3) Ended up with best ET of 10.15 at 131.54mph then began my last effort to get a 9.999 time slip.
4) I replaced my steel deck lid (70lbs) with a pin-on glass deck lid (10lbs), replaced the steel "tub" in the trunk that the plastic fuel cell was inserted into (the "tub" weighed 35lbs) and put aluminum floor in the trunk and installed a very light aluminum 5 gallon fuel cell....all in all I took 125lbs out of the car from the rear axle back.
5) I took another 60lbs out of the car in the middle of the car for a total of 185lb reduction.
6) With good air I was looking for the elusive 9.999 ET.
But...I found the limit...
A) Car would NOT HOOK after taking the weight out of the rear and no matter what I did it would NOT get better than a 1.485 60', slower than my old 1.40 60' and my best ET with the weight reduction was 10.22. The 131mph was still there, but not the ET.
B) I have no more economical way to take weight out of the front of the car and I have to put the weight back into the rear to get traction.
C) I have no room for wider slicks so I can launch at more than my normal 3600rpm off the trans-brake.
D) I do NOT have the money to install ladder bars or 4 link and a full tub and big tire so I can put on 14" wide slicks so I can launch at 4500 RPM and get my 60 foots into the high 1.30's. My 11.25 wide slicks will only provide traction up to 3600rpm launch BEFORE I took the weight out of the rear.
E) The car is street legal now and I don't want to put in lexan windows, gut the interior, etc, etc to take out weight up front to go faster.
F) The motor makes right at 750HP right now and I cannot do things to make more horsepower without risking blowing the main caps off the block. I have steel billet main caps and a steel billet girdle and that is all I can do for this block.
G) I am NOT a Nitrous Oxide guy so I am not going to do that for more power.
I have now accepted the fact that after 3 years I have found the lowest ET (10.158) that this old girl is going to give me....and I am ok with that.
