Purchased new leaf springs
Doug Larsson
1:00 AM
I purchased new leaf springs for my 73 Charger SE looks prett straight forward installing them any tips or tricks I need to know before tackling this beast ?
I normally will jack up the rear till there is no load on the rear shackles, disconnect them then lower the rear so the springs are clear of the rear bumper/valance. Remove one side and replace, then do the other. Jack it back up and connect the rear shackles with NEW bushings.
Super stock type springs have a slightly differnt arch left to right, could account for the difference.
Spray all nuts, bolts, shackles with penetrating oil... Go have a drink... come back the next day, spray again... Have a drink.. on the 3rd day after spraying liberally again THEN you may be ready to tackle this task.
Yep way ahead of ahead of you sir lol.
Stock height or +1? Look forward to see how it sits with them.
That's amazing, their price has not changed in 6 years since I purchased mine!
I purchased all new bolts nuts u bolts and nuts the iso pads it all came to$491.00 $100.00 of it is shipping so I thought it was a great deal. I think when I priced Eaton it was like$760.00 for the same stuff.
So I'm disassembling my leaf springs everything is going great then I run into this problem. The bolt is hitting the frame I can't pull the leaf spring out. Is my only option going to be to find a way to Houdini cut that that should be fun.
They are installed like that for a reason, Safety. You will need to remove the hanger from the frame and lower it to change out the spring.
I’m in the process of doing a refresh on my rear axle & leaf springs. You can remove the spring hanger from the body bracket-4 nuts to the rear. For safety, make sure the rear axle is supported if still in place.....Jim
