Doug Larsson
- 10:06 AM
- Apr 18, 2016
where did you get them?ESPOLook nicewhere did you get them?
Are both springs same in length or is the right longer than the left?I purchased new leaf springs for my 73 Charger SE looks prett straight forward installing them any tips or tricks I need to know before tackling this beast ?
$130.00 each $260.00 for the pair.What did you pay for these?
There both the same length 6 leaf.Are both springs same in length or is the right longer than the left?
These are a factory replacement.Super stock type springs have a slightly differnt arch left to right, could account for the difference.
Stock height.Stock height or +1? Look forward to see how it sits with them.
That's amazing, their price has not changed in 6 years since I purchased mine!$130.00 each $260.00 for the pair.
I purchased all new bolts nuts u bolts and nuts the iso pads it all came to$491.00 $100.00 of it is shipping so I thought it was a great deal. I think when I priced Eaton it was like$760.00 for the same stuff.That's amazing, their price has not changed in 6 years since I purchased mine!
I’m in the process of doing a refresh on my rear axle & leaf springs. You can remove the spring hanger from the body bracket-4 nuts to the rear. For safety, make sure the rear axle is supported if still in place.....JimSo I'm disassembling my leaf springs everything is going great then I run into this problem. The bolt is hitting the frame I can't pull the leaf spring out. Is my only option going to be to find a way to Houdini cut that that should be fun.
