best brand ?
moparsquid
8:42 PM
spring valley ,ca.
Hello at the present I'm running comp engineering 3 way adjustable front drag shocks I need to replace one that is leaking ,my question is should I go back to the same brand or I've noticed that LAKEWOOD offers a 3-way also ?
If you're only replacing one, then get the same brand so they match. If your replacing both, then sure why not try another brand.
I have no experience with either shock, maybe someone else will chime in.
I run Viking Crusaders out back and Warriors in the front. Highly Recommended. I drive the car everywhere and hooks hard with Caltracs outback.
Hey 2quick, what kind of rear tires do you use and about how much power are you making?
M&H Radials 390/45-15
Somewhere between 600-700 not sure!
