Bad Sport
Deceased, But not forgotton
Bad sport is mostly right
I would have been more righter, lol, if I hadn't left out a sentence.
Glad you asked....I conducted this very experiment on my buddy's driveway a while ago...
Suregrip marks.....
and a Pegger......
This was NOT an experiment!
Hopefully that concludes today's lesson.
So, in today's world, if your not doing 70-75 on the highway, you get run over....my 69, 383, 4 speed car pretty much screams at those speeds.....does that mean I have 3.55 gears? (Or higher)? Is there simple way to find present gear ratio? If wanting highway cruiser, what should I be running?
PS....running 295/45/18 on rear
Yeap, that's exactly where I was with 3:55's before the 6 speed.. now it's 1,800-1,900 rpm at 80 mph lol.I have 3.55 rear gears, 295/50-15 tires (26.6" tall) and at 65 mph I am turning 3100 rpms. 70mph is about 3250 rpms.
Send me over a blank check, I'll put the Tremec in.....not all of us are Rockafellers....Jesus Chrysler this is painful. Like described, plant your right foot and count the streaks. Don’t like laying under the car with a crayon, etc. i have never known or cared about offset or tire diameter. Put a Tremec in and be done with it. 1935 @ 65 w/SST.
Thanks......I'm finding that out about the 2 series gears....cant find em.....probably will have to suffer with 323, has to be somewhat? Better than 355You have a suregrip.
3.55 gears are a good compromise gear, biased toward street performance, 3.23 is the best compromise, decent acceleration, decent revs on the highway. 2.76 or 2.93 are freeway flyers, but off- the-line will suffer. You have to decide what you want, how you plan to use the car, and what compromise you can live with.
I also believe that two series gears are hard to find used, and impossible new, but I may be wrong about that.
That’s me! How did you know.Send me over a blank check, I'll put the Tremec in.....not all of us are Rockafellers....
An overdrive tranny is cheaper than a set of rear gears?There's not much of a difference between .23 and .55. If you consider the engine "screaming" (with the understanding that a: it's a car from an earlier era and it will be noisier and b: the 383 is a short stroke, long piston engine and designed to be driven for hours at 3500rpm) then you need to save up and change the transmission. I'd suggest an A833OD as a good alternative that is lower cost and basically bolt in, give or take. You need one out of a truck or van. Have the bellhousing hole enlarged for it, and bolt it in. You'll need to take care with the shift levers and adjustments of the rods, but it's an OD drop in that will make a difference for less than a second 8 3/4 pig.
Ahhh......ok thanksThe difference between 3.23 and 3.55 is around 9%, so 3000rpm with 3.55 goes to around 2750.
I think what moper is saying is that a factory overdrive 833 is a lot cheaper than a five speed tremec.
The difference between 3.55 and 2.93 is around 17.5% so 3000 rpm goes to 2450.
So......"383 is a short stroke, long piston engine and designed to be driven for hours at 3500rpm", your saying this is normal and ok? Then......maybe I should just leave things be.....its been long time since I had my 1st RR, and just dont remember the motor "screaming " that much WAY back then! LolThere's not much of a difference between .23 and .55. If you consider the engine "screaming" (with the understanding that a: it's a car from an earlier era and it will be noisier and b: the 383 is a short stroke, long piston engine and designed to be driven for hours at 3500rpm) then you need to save up and change the transmission. I'd suggest an A833OD as a good alternative that is lower cost and basically bolt in, give or take. You need one out of a truck or van. Have the bellhousing hole enlarged for it, and bolt it in. You'll need to take care with the shift levers and adjustments of the rods, but it's an OD drop in that will make a difference for less than a second 8 3/4 pig.
