- 9:26 PM
- Apr 13, 2012
- Granite Bay CA
I have dealt with slight oil leaks with my 3 different 440 engines. I've always used a windage tray. In a few cases, I have used lock washers on the bolts. I still got leaks. I'd drive the car and see small drips under the car. I'd get it on the lift and see oil on the bolt heads, dripping off to the floor. There are sometimes oil streaks on the headers as well. I tried different bolts, tried lock washers, flat washers....I gave up trying to figure it out.
A guy over at DodgeCharger.com just wrote that the oil pan bolts .....need sealant because the threaded holes in the block are open to the crankcase.
Really? I did NOT know that. 19 years I've owned this car and I learned something today.
I built 2 440s before this engine. I've had this one apart twice, I've had 3 different oil pans on this engine and I simply did not notice that the mounting holes were open. The intake mounting bolts are also this way. I used to get some oil in the valley on the valley pan and learned after mentioning it that those holes needed a sealant. This revelation regarding the oil pan mounting holes came as a surprise to me.
Come on, guys...'fess up. I can't be the ONLY guy that didn't know this!
