Derwud
Got a hold of Jerry after selling my CVF Beast to 5.7. Gotta start Junk yardin now for the other pieces.
I’m liking it. Can’t wait to be able to use the AC!
I can ask if there’s an rpm limit on it but it’s irrelevant in my mind as you could always pulley up to slow down the alternator or add rpm activated cutouts. I’ll test the limit at this one will easily see 7000rpm.Are there any R.P.M. limits [ in small print ] on these kits?. I ran into that from Vintage air kit for a O.T. sbc , think it was 6,000 rpm - not much rpm for a built small block. I do turn it to 6500 with no problems as of yet and still can't figure what the limiting factor is ,anyone know?.
I really like that setup, good to see they finally realized that they needed to offer a real serpentine. Always thought that was retarded, switch to serpentine and still have 2 belts that need adjustingI can ask if there’s an rpm limit on it but it’s irrelevant in my mind as you could always pulley up to slow down the alternator or add rpm activated cutouts. I’ll test the limit at this one will easily see 7000rpm.
. Can you get power steering as well?Yes, it actually bolts on the lower corner of this setup under the alternator.I really like that setup, good to see they finally realized that they needed to offer a real serpentine. Always thought that was retarded, switch to serpentine and still have 2 belts that need adjusting
Hmmm, with an RB in the upcoming future. Can you get power steering as well?
That's the manufacturer and style I bookmarked. I was talking with him about the cap and girdle system he sells, and he told me about their serpentine system.
9500rpm for us drag racers. Less for extended WOT use.Are there any R.P.M. limits [ in small print ] on these kits?. I ran into that from Vintage air kit for a O.T. sbc , think it was 6,000 rpm - not much rpm for a built small block. I do turn it to 6500 with no problems as of yet and still can't figure what the limiting factor is ,anyone know?.
Yeah I thought it was pretty good. With my small turbos, I would expect power to peak fairly early so there’s no way I’ll test that number.9500 ? , that's pretty damn good. Way better than the Billet Specialties tru trac that i had used before.
Hell of a lot cleaner than the others-------jmoView attachment 778295 I have the 440 source stuff but also have no a/c to worry about
The Wraptor serpentine w/tensioner by CVF is "busier" than the Beast, but it is a true single belt, tensioner system.
The Beast looks similar to the 440 source, and they have a 3rd choice.
The Wraptor is the best one for me.
Very cool!View attachment 778571 View attachment 778572
That's ok to have that opinion.Too much garbage for me -----jmo
