kjalltrac
I'm having a hard time selecting a solid flat tappet cam. Anyone has any good real life experience they want to share?
My engine feel sluggish after 5000rpm and I have my mind set swaping my hydraulic cam for a solid instead.
Want to get down to 11s at the quarter without nitrous.
This car is 90% weekend driven, no powerbrakes.
Current combo
L2355f stock bore pistons
Edelbrock E-street heads (cleand up and back cut valves)
Headman 1 3/4 headers
3" exhaust
Edelbrock rpm dual plane intake
Quickfuel 850 dp with electric choke
Comp cam hydraulic 284h cam
10.1 comp
8 3/4 with 3.73 gears
Tf727 manual revers pattern
Hughes 3000 stall converter (4000rpm flash)
Ss springs
10/90 front shocks
26" x 9" hoosier slicks
Stock weight 64 belvedere
Best n/a so far 12.24s 108mph 1.74s 60'
I have the trigger on this lunati.
Solid Flat Tappet. Pro Street/bracket race cam with good mid range to high end torque and horse- power. Needs 3200 RPM stall converter, headers, 11:1+ compression ratio and 3.90+ gearing. Rough idle.; Advertised Duration (Int/Exh): 280/288; Duration @ .050 (Int/Exh): 251/259; Gross Valve Lift (Int/Exh): .566"/.586"; LSA/ICL: 110/106; Valve Lash (Int/Exh): .016"/.016"; RPM Range: 2800-7000; Includes
Current combo
3" exhaust
10.1 comp
Ss springs
10/90 front shocks
