67 Plymouth spring and mini tub mod
Nice work your car is coming along real good with those updates.
Stock cr14 fuel tank. I've seen where a couple of people have asked if its possible to use a stock fuel tank with inboard springs. Here's your answer .
Getting ready to install. The only thing different is compression from 10.5 to 11.9.
Drilled holes in the floor so the main hoop will drop in. I'm hoping I'll be able to weld all the way around the a pillar and rear support bars
Jw bell with the wheel. Freakshow powerglide and converter
What did you use for gearing in the diff with power glide. I'll bet that is going to be a blast out of whole with the glide.
