grander
Hi All,
First off, as always thanks in advance, tons of knowledge on here... Second - apologies for the long read!
I have a '64 Phoenix (330/440 4 door) that I can't make a decision on an engine for.
I already have a cruiser in the shape of my 63 cadillac so am planning on adding to the bruiser part of the shed.
Wants are to possibly run in the 11's at the track but also see some sprint time at the local circuit. I also want to take part in the local 'drag challenge' which is a similar to your drag week.
Currently running a 727tf (stuffed and needs rebuild) and 3.9 9"ford though would love to change out to a 5sp manual sometime.
SO, initially the way I see it is:
360/408:
Pro's - already set up for.
Cons - projected end $$$
383 6 pack:
Pro's - It's a big block. It's a 6 pack.
Cons - comparable power output? Weight. Transmission and exhaust - not really a big deal at this stage
400/451:
Pro's - seems to be everyone here's favorite. Best power potential. already has an auto.
Con's - weight and exhaust change. FT cam.
The car has a 360 which ate a cam lobe so I was intending to build this up into a very stout 408 with some attitude; indy heads and manifold big hyd. roller etc.
By the time I build this motor and rebuild the auto (with 31/2 - 4k stall) and back on the road I figure I'm looking at about $20k aud.
A 383 6 pack has come up locally for $6k. I figured give it the once over and a standard freshen up with a nice lumpy cam and mild heads and then either get the BB auto to suit or do the manual conversion. This "should" come out cheaper than the 408, be just as fun but not as highly strung.
Hopefully the link works:
And then there is a 400/451 stroker. This has been built by a well known racer /builder basically from his left over parts. Already has a rebuilt auto and is ready to go. Not sure about the FT cam specs though or the 'stock' heads but still priced at $10750.00 SEEMS like a bargain. Basically bolt in and go.
So?
WHAT DO I DO? WHAT WOULD YOU DO?
Graeme.
360/408:
383 6 pack:
400/451:
So?
Graeme.
