kjalltrac
Welcome to join the club
			Found this, very interesting.
Pretty close to my combo
https://www.hotrod.com/articles/mopp-0312-solid-vs-hydraulic-lifters/
I have all Winter to figure that out I guessAre you looking at solid cams as well?
Wallace racing calculator says 8.9 dynamic using 52 degrees IVC.So.. Narrowed it down to these two cams.
Trying to calc the dynamic compression but the ivc for the lunati is speced at 0.02 lift and the Hughes at 0.05 lift.
Lunati 30230742:
Dur@.05: 251/259
Lift. 566/.586
Lsa/icl: 110/106
Ivc @.020: 52 deg
Hughes stl4650bs:
Dur@.05: 246/250
Lift:. 576/588
Lsa/icl: 108/104
Ivc @.050: 47 deg
Im at 10.3 static comp
I've calculated the Hughes cam to be at 8.3 dynamic comp.
Can anyone help me calculate the Lunati please.
That must be wrong, rhe wallace calculator requires seat to seat specs.Wallace racing calculator says 8.9 dynamic using 52 degrees IVC.
It does require seat to seat. I used the .020 figure. Using Lunatis advertised duration of 280/288 it gives an IVC of 66 degrees. Putting that in Wallace gives an 8.09 DCR.That must be wrong, rhe wallace calculator requires seat to seat specs.
I only have 0.05 and 0.02 specs
