Dreamcatcher
Will fish for food
I saved one by pulling the heads spraying pb blaster and tapping each piston daily with a block of wood and a hammer. After a couple days work the crank with a breaker bar.
Team,
So what are your thoughts on saving a rusty engine? The motor in the '67 Coronet is sezed pretty hard. Took the all the pull offs on the front of the motor, intake and carb ect. Valve covers are off and the exhaust manifolds ect. Been using Marvel Mystery oil per cylinder and Seafom Deep Creep on the rods and bearing ect. I see a lot bright metal on all the cam bearings and some surface rust on the rods and lifters...but not too bad. Got the harmonic off and threw a crank socket on these with the 18" breaker bar, but no movement. Also pulled the dizzy and got a lot of lube in there.....trying to save this motor, as she is pretty low mile. 52k original.
l always got told as s young guy if an engine was seized to dump the entire engine into a vat of diesel and let it sit there soaking.9 times out of 10 its supposed to work lve never tried it personally but l thought id put it out there anyway lm sure someone else has either tried it or heard of itTeam,
....nailed itFirst one, tightened instead of loosened.
Just guessing.
Were you able to get the broken bolt out?....nailed it
Just taking a wild guess, okay? Yep, piston rings rusted to the cylinders are a sure lockup. Usually the first to happen, even just with condensation inside the engine.Cylinders had some very minor surface rust.
Good news on the bores too is that the car only has 53k original miles on here. Never been bored.Just taking a wild guess, okay? Yep, piston rings rusted to the cylinders are a sure lockup. Usually the first to happen, even just with condensation inside the engine.
First thing I'd do, if you have the means, get the bore size of the block. If it's already .060 over...probably not worth fooling with.
Go easy with the block of wood...just tap, tap, to work the ring's rust loose. It will take time. Yeah, I've dealt with one like that.
I believe I'll do that next. Been super gentle on her thus far. I'll drop the center link in the suspension to drop the panAre you getting penetrating oil on the rings from the bottom, too?
IE rotating the block on the stand every few days and shooting the skirts.
