- 12:13 PM
- Jan 16, 2011
- NorCal Sierras
edited; to Biomed's questions & response
if you're going with a 0.600" gross valve lift roller, of any kind
or a flat tappet camshaft, for that matter
you will have a higher maintenance & probably a higher parts attrition too
the nature of the beast, it's just physics
these kind of builds are unpredictable at times
the only way, is to check it regularly, you may save it
so you don't kill the whole engine', all at the same time
better to be safe than sorry, especially when you spend $20k
(far more than $10,000, like it sounds like you are going to) on parts,
expensive aftermarket heads, a expensive aftermarket block,
crank, rods, pistons etc. &all that billit roller valve-train, ain't cheap either
there is no way around that, if you don't want a catastrophic failure
especially in the valve train dept., which is the culprit 'a lot'
& usually from not checking it often, to see a problem before it's catastrophic
bigger cid doesn't matter on that side of it either
& yes it'll make more torque & probably more hp at a lower RPM too
because of the 100+ more cid's, it'll probably eat more parts too
& I know it'll eat far more fuel
, that's the nature of the beast
(yes it will want more camshaft to take advantage of the heads & added cid's)
, that's the nature of the beast(yes it will want more camshaft to take advantage of the heads & added cid's)
six pack induction
lash never changed and I wasn't using anything special for pushrods, springs used were for a roller cam (triple) and I removed the small spring and shimmed it up to spec, valve train stability is the key and good oiling (single external in my case).
