As said above above one pour just put 1 truck on one side and the second on the other. We starteReasons maybe lack of man power. Power screed might not be long enough. Availability of concrete or any number of other reasons.
Gotcha. Here in the freezing north you really want all structural support 3-4ft deep in the ground, once the footing/foundation is in the floor is nothing more than a floor that can be poured at any time. Personally I like doing it this way especially in Ohio where the weather is so unpredictable, you've got shade, shelter and control over the temperature. This particular addition is pole barn style but instead of burying post 3ft deep I pour 3ft deep concrete post and leave them well above ground level then anchor the post to them. Here's a picture where you can see the post, this allowed me to build a 6" thick perimeter of foam around the slab as well filling the cavity under the wall. I'm leaning towards metal siding inside (easy powerwash cleanup), if so I'll stud in between the post horizontally 2' on center giving me an easy way of insulating and hanging the siding.No, my point is that out here, the entire slab is poured before any framing is done. All perimeter walls rest ON the concrete.
Another reason at least for me is keeping all framing well above ground level... again Ohio weather.
