- 11:23 AM
- Apr 13, 2012
- Granite Bay CA
How are your welding skills?
These cars used a sturdy steel crossmember that was used to support the engine and front suspension & steering. It is referred to as a K member because it looks like the capital letter K. They can benefit from adding some reinforcements. They were built in an era when handling wasn't such a priority as it is today. The steering box is bolted to mounts on the K member that can flex and move around, making steering feel loose or sloppy. I'l admit that welding in reinforcements here is not a simple task but it is something I do on every car that I plan to keep. With the steering box solidly mounted in a reinforced K member, MORE of your steering wheel input makes it to the tire.
Another way of looking at it is to envision a scenerio where every component from the steering wheel to the tire has some amount of slop to it. The steering wheel can be turned back and forth over a quarter turn but because of the slop, the tires don't turn at all. As you replace worn parts, eventually the steering wheel can be turned LESS to get the tires to react because the slop is eliminated by replacing everything that is worn out.
