- 1:04 PM
- Mar 28, 2014
- South Louisiana
That seems about right. I should be able to find some more power via the timing.Basing things on a 3700 all in car with a chassis that hooks good and an actual on track 291fwhp your ticket would look like>
60 Foot E.T. : 1.89
1/8 Mile E.T. : 8.58
1/8 Mile Trap Speed : 79.24
1/4 Mile E.T. : 13.59
1/4 Mile Trap Speed : 99
@333fwhp it would be>
60 Foot E.T. : 1.81
1/8 Mile E.T. : 8.20
1/8 Mile Trap Speed : 82.88
1/4 Mile E.T. : 13.00
1/4 Mile Trap Speed : 103
So you have the 333hp (weight/mph) the numbers explain it all...radials of any kind, street/drag and stick cars are not a match made in heaven.
My best guess at HP has been about 425-440HP. The thing is, my dad had the exact same car, so the weight should be equal. He had a 389 Tripower, with a jetting kit, spark plugs 1 range colder, thin head gaskets, "poly locks" to get a couple hundred more RPMs, short throw shifter, transistorized ignition, and cheater slicks. I think he may have had a 4.11 ring and pinion gearset. I wouldn't want any higher gears than the 3.80 because I'm already pushing up on the rev limiter.
So I think between the unexplored and recognizable "less than ideal" setup of the distributor, which has a lot of potential because it is one of the best ignition systems available, and the traction difference between the drag radials on my car vs the slicks he had, and BAM! there's the 8/10ths of a second that I need to cut to reach our goal.
