silversedan
don[t forget you also have to remove the fuel pump!
That was what the fsm suggested. If someone wants to make extra work r&r the intake plus buying a new gasket that's their call.It will take less time to pull the intake than to dic around fishing for lifters . just follow the procedure and make your life simple
Shoot, man...That is a backyard rebuild, not a cam swap!
I was thinking of possibly sneaking in a different camshaft in my 1970 Satellite in-situ (NOT removing the motor). Wondering if anyone has done this before and can comment on its PITA factor?
For sure I would have to remove the radiator but not sure what else on the front fascia...also would I need to get access from the top by removing the intake manifold?
Thank you for reading/responding etc...![]()
