Suspension Upgrade Ideas
68HulkCharger
2:22 AM
Minneapolis
So I'm looking to upgrade my suspension and I'm hoping for some ideas on the best components to change. Here are my initial thoughts:
Bilstein Shocks
Hotchkis Sway Bars Front and Rear
Hotchkis Subframe Connectors
PST Torsion Bars
Not sure if its worth putting new leafs on or not.
whats the reasons for upgrades ? Touring,dragging or cruising.
Bilstein Shocks
PST Torsion Bars
As already said - we must know your final vision for the car. Is it racing?
I haven't used any Hotchkis upgrades, but I did upgrade to PST torsion bars (1.03"). I wanted to stiffen things up a little in the front end. I also upgraded to polyurethane bushings, upper and lower ball joints, etc.
In the back, I replaced all the leaf spring bushings, and had the springs re-arched. I also swapped out those goofy air shocks for a set of KYB excel gas shocks. I'm happy with the set-up so far.
On my 67 Belvedere, I went with a Hellwig 1 3/8” hollow sway bar, Firm Feel 1” torsion bars, ESPO HD leafs and Hotchkis/Fox shocks. Here are the reasons why I chose the mish-mash of parts. Originally I ordered a Hotchkis sway bar but when it showed up, the wrong bar was packaged inside. Also, their frame brackets and end link brackets require welding. I saw that AndyF liked the Hellwig mounting brackets so that was enough of a recommendation for me. The Hellwig kit is very nice. The Firm Feel bars had a wheel rate of under 200in/lbs so it still rides nice. The Hotchkis shocks I got for a very good price from FABO. All of this replaced pretty low mileage small block suspension parts and they made a huge difference. I also added a Dr Diff disc brake kit. Next will be a Firm Feel 20:1 manual steering box.
Wow. Great info. Thanks much
Just buy the entire Hotchkis TVS system for the car. Dial in -.5* of camber, +6* of caster, a little toe in and you'll be amazed at how well these land yachts can handle. I'm talking almost ZERO body lean in hard turns and a level of driving confidence you have to feel to believe. I can only imagine how much better my car would feel with the borgeson box, boxed LCA's, torque boxes, etc...
That is something I was considering too but I wasn’t sure I needed that extensive of a kit.
Some good recommendations above. Couple other things that I have been doing is to add lower control arm stiffening plates from PST, 11/16" C-body tie rod ends, solid tie rod adjusters, and Firm Feel K-frame stiffening kit.
