MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
- 7:22 AM
- Nov 24, 2015
- Moreno Valley, So California
A little safety tip to throw out there. Number one. Always, always have a properly rated fire extinguisher handy when working on the fuel or electrical system on your car.
The only purpose of spraying around the intake manifold. carb base with a "fluid" is to find a vacuum leak by finding an RPM change, Correct ? Does it matter if the RPM's go up OR down to find the leak? It is very dangerous to be spaying ANY flammable liquid on a hot/running engine.. We always just used a spray bottle with water. The RPM's will drop when there is a vacuum leak detected with water and No chance of any fire/damage in the engine bay. Another way if you must use a flammable is with propane gas. Heavier than air, won't swell the gaskets from soaking them .
https://www.hunker.com/13414896/how-to-find-a-vacuum-leak-with-propane
