Who said anything about times?
Tires and spinning have nothing to do with trap speed. That is why mph used, not et.
So if I spin out of the first 60 feet, my mph will still be the same by the end of the 1320, then if I hook?
Probably not exactly the same, but much closer than the e.t will be. If you spin hard off the starting line, pedal it and get back in, you could easily slow down a half second or more, and yet lose only a mile per hour or two. Or maybe not even that. I have seen cars spin hard , and run better mph, from having more wheel speed after it hooks up.So if I spin out of the first 60 feet, my mph will still be the same by the end of the 1320, then if I hook?
Yes, if everything else is equal.So if I spin out of the first 60 feet, my mph will still be the same by the end of the 1320, then if I hook?
Just used that calculator on a stock 2016 Charger R/T, 4800 with driver 103MPH claims 409HP
Dodge says 370HP how can 40HP difference be accurate?
Can you post the details of the car's track time and weight or a link to it.
... I have seen cars spin hard , and run better mph, from having more wheel speed after it hooks up.
