- 7:52 AM
- Oct 16, 2014
- Salisbury, Vermont
Glad I saw this thread. I had a shaft come off on a mil truck back in the day. U joints failed. Scared the crap out of me.
Glad YOU are OK!
Here is an option I like & need to install:
http://www.manciniracing.com/bofrdrlo.html
Ouch!I wouldn't call a slip yoke failure a "transmission explosion". Same thing happened to me under the same circumstances but I had a driveshaft loop.
View attachment 982007 View attachment 982009
sounds like over running clutch bad ****Hi everyone,
while accelerating full throttle at around 4000rpm doing about 100mph, my transmission suddenly and with no previous sign of failure, exploded. No one was hurt, no shrapnell inside the car. Drive shaft yoke at the tranny has sheard off. I was able to coast and stop safely on the breakdown lane. Apart from the destroyed transmission and the driveshaft, everything else is fine. Does anyone have any idea what could have caused this?
69 Road Runner, 76 440 with purple cam, TF727, 3.23 gears, 2500 stall, no extra tranny cooler, only stock transmission oil cooling through stock (wide version) radiator.
I've had the car for six years now, engine/transmission worked absolutely fine until then. Small oil leak at the rear of the transmission. Tranny oil changed two years ago. Everything seemed to be balanced just fine. No vibration or anything.
I was driving for roughly 15 minutes when the tranny failed and had been rolling around at 2000rpm until then. I always try to give everything time to reach proper operating temp. Engine water temp has reached 180F ca. 5min before I put the pedal to the metal and the transmission destroyed itself. Water temp was still at 180F when it happened.
Thanks for any ideas on why this could have happened or how to avoid this in the future. No speed limit, by the way, as the "Freeway" is an Autobahn here in southern Germany. Regards Mike
YepTrans blew apart because of the yoke/strap failure. Overrun clutch grenaded at the tailshaft/housing because it went beyond design parameters.
If you were in it to 4k rpm @100, what did the rpms jump to once it let go?
Overrun clutchYears ago I had a rear ujoint cup get loose at about 60 mph. It also broke the trans tail housing and bent the tailshaft. Driveshaft never became disconnected so there was enough vibration that i remember my interior rear view mirror rotating. I do believe the tail housing broke immediately as the smoke from fluid on the exhaust was instantaneous
Awsome transmission understand how it functionsOverrun clutch
Nope. The lower roller clutch is used in 1st gear only. They get a bad rap.sounds like over running clutch bad ****
