beanhead
Easily Offensive
Ok, based on the stats...nothing jumps out as a real obvious cause. There's a possibility you're hitting lean for a moment at WOT, with the smaller secondary carb and your combo. I'd pull a spark plug and cut the the insulator off so you can get a real good look at the fuel ring at the very bottom. If the tune is close there should be about .100" of ring down there. Thinner than about .080", or too lightly colored and it's lean WOT for sure.
I'm slightly surprised at the 165 psi, with that cam, and quench distance..I'd think it would crank a little higher than that. My 440 + .060"--roughly the same cubes as yours--cranked 160-165, with a bigger cam, installed 4 degrees advanced, just south of a true 9.5 SCR with the pistons down .060 in the hole (and a .039 gasket) and it never pinged..and I'm down in the valley, it be hot here! Same junky CA pump 91. 850 speed demon, bigger jets than stock, same heads as yours. I ran a 750 QF carb for awhile and even dialed to the max, that engine wanted more.
The disclaimer here is, this all assumes the numbers you have numbers are accurate..and that what you're hearing is definitely detonation.
