You want to cut the threaded portion off at the base. Of course, that means a new plug, or plugs...
this isn't mine, just a pic I grabbed off the 'net but shows what I mean.
The dark ring at the very bottom of the porcelain, indicates WOT. These in the picture look to be too wide = rich, but gives you an idea.
And, not really relevant to your issue, but yours look rich at idle and close to being too hot..if you can re-curve the distributor to get 20 at idle with the same 32 total, you may get some improved response..just for future thought.
Looks like mine is way too rich. So if it’s leaned out more it won’t help my issue. Although at first when these were installed my tune was crap for a few hundred miles and my initial advance was set at 10-12. Later with same plugs it got the advance dialed in and no more rich fuel smell before these were swapped for the other plugs trying to help with my detonation issue.You want to cut the threaded portion off at the base. Of course, that means a new plug, or plugs...
By the way these are NGK BPR6ES. Now in the car are one level colder NGK’s.
Compression check hopefully in the next month.
