mr. b
looks great nice work
The paint on your car looks amazing.Nice vert...though I'm a bit partial. Good job on the inside panels. I was lucky, my panels weren't "speakered". Rear trim fasteners look stock to me (had a 70 Sport Satellite). My guess is the orig owner had the dealer add the rear trim. Also partial to the wheel well trim. Mine also has the bumper guards, very rare.
One question, do you remember removing the quarter glass/frame? Trying to remove mine, passenger side. FSM says to remove front guide first, but I can't seem to get it out.
thanks! Started it earlier this year and should be done in a month.---hopefully---looks great nice work
The lower control arms, center steering link, sway bar, steering box, spindles are original as far as I know. Not sure what 'Ma' is? The original engine block blew up 'real good' around 1985 and is long gone.I’m not sure how correct you wish to make your car but the suspension and k frame are all marked from Ma. I know you bought reconditioned k frame , unless you have damage to it you may double check. It will be a stunning car when completed ! You may even get lucky and locate the orig drivetrain.. it will be great either way but i always try to make them how they used to be unless too much is gone . Good luck and don’t get discouraged! Be patient and do it the best you can. Keep us in the loop !
No, I have 100 hours in just blocking, another 250 in body work. Paint, drivetrain rebuild, restoration of sub assemblies, interior, and the list goes on. I figure 12-15 hundred hours total. I think you are real light, or the car didn't need a lot.figure roughly 500-600 hours including body work. Does that sound about right?
My mechanic pal is doing the windows and interior etc. I'll ask him about removing the passenger side.
