- 12:11 AM
- Apr 13, 2012
- Granite Bay CA
Hmmm...I'm guessing that relates to a vacuum signal issue, right?
Thanks. I'll look for the SD card slot.First you need to have the Sniper software installed. Then you have to create a log with the handheld in the car. Once you've completed a drive, pop the SD card out of the handheld and download the file onto your computer.
The problem with a PCV valve (or any vacuum leak with EFI) is that the Sniper self adjusts the air fuel ratio automatically. The Sniper senses the extra airflow and it adds fuel to keep the AFR where it is programmed to be. So if the PCV valve sticks open at idle the idle speed takes off and the car will take off.Hmmm...I'm guessing that relates to a vacuum signal issue, right?
You should not use a PCV valve with EFI. Holley doesn't talk about it for some reason but a PCV valve failure can cause lots of issues with EFI including possible loss of control. I have a customer who had a very close call when his PCV failed open. The answer is to convert over to a fixed orifice PCV valve. You can buy fixed orifice PCV valves for Chevy engines but you have to make your own for a Mopar.
Please do post on how this goes. I’m super curious and am considering it for my 67I finally gave in to the dark side. Purchased a Holley Sniper EFI for my GTX. I've been having a weird lean pop at mid-low rpm that I just cannot tune out on my Edelbrock AVS carb. Said "F' it and bought it.
I already have the Holley Sniper EFI gas tank with 255 Walbro pump and an o2 sensor installed so it should make for an easy swap. I went with the EFI 4150 550-516 unit. 800cfm and good to 650 hp. Has a built in pressure regulator and is what sold me on it.
Going to document my install as I go. I'm curious as to how my throttle and kickdown stud fit. I am assuming I'll have to tweak it.
I installed the Holley application and got a long data log. Not really sure specifically what I'm looking for but it is a play by play of my drive. Neato!!
View attachment 1041889 View attachment 1041890
Oh sweet!
Gotta be a legend or something for all those lines yeah?
Cool man
So you floored it, rpm climbed (no shift), don’t know what do say about A/F (few jumps there are interesting), and fuel flow was off the chart!
Thanks for sharing; never saw one of these before...
So 12.7 AFR WOT, correct?
Yes, a gutted PCV filled with epoxy and then drill a small hole. Something around 0.100 diameter should work. I've started making fixed orifice PCV valves but I haven't put them on my website yet. You can see it mounted on the passenger valve cover on this engine.So like a gutted pcv valve with a small hole on the big end?
