Block # gurus...
Measure the dia of the dish, and the depth.
V=pi*r^2*h
Where:
r=dia/2
h=dish depth
This will get you close enough. As far as the deck height, measure it and use:
DHv=(b/2)^2*51.48*h
Where:
DHv=Deck Height Volume
b=Bore
h=Deck height
2315s are out...no std size available.
I just measured all 4 open holes...4.257 from top to bottom
Deck height is measured with the piston at TDC, then measure from the block deck to the top of the piston (not the dish).
Do yourself a favor, and disassemble the block, align hone (if not already done), square the block (it has not been done), and bore cylinders 0.030" over.
Im coming up with 10.4....does anyone see an error?
Assuming 51.48 is gasket bore? Or what does that represent?
That is a number that you use to basically convert the result to CC's. (for this example) What gasket ( PN#) are you using? You should also be using ARP head bolts or studs. The OEM headbolts will damage the aluminum heads.
Cometic C5459-027 is the gasket
2.88 diameter of dish
.09 depth of dish
Humor us.. Recalculate using a positive number for piston dome volume.... If positive is wrong your C/R will increase substantially... Ain't no way a 383 with dished pistons is 9.5-1 C/R...
69bee had that formula as ...im guessing ....a TLAR...(That Looks About Right) estimator...i guessing we can assume 10-15% error in it? Id like someone else to run those dish numbers...see how far off base this really is.
Dish is 2.88 diameter x .09 deep.
