Johnpat
I'm not a carpenter,but can replace metal,most good doors are aluminumReally? Well metal also rusts at the bottom.
I am not a carpenter but I can replace wood. Most doors are aluminum skinned with a wood skeleton.I'm not a carpenter,but can replace metal,most good doors are aluminum
Better get that is writing. Concrete alone averages about 8.00 a square foot.I'm planning on:
- Metal
- 14' wall
- 40' wide minimum
- 60' long
- Hurricane rated 125 mph. Open span inside. See pic below.
- Steel reinforced concrete slab
- 3,000 psi concrete
- 4" thick except thicker around perimeter and piers.
- Insulated film (forget what the e stuff is called)
- No electric
- No plumbing
- Doors & windows extra.
- Above was quoted two weeks ago: $24 per square foot "turn key"
- Clearing lot and all stumps: $4,000 and is my responsibility to sub out.
- Dump truck loads of "dirt" is my responsibility to sub out. Around $400 per load.
Not going with wood because of:
- stratosphere pricing for lumber.
- contractors not interested in building anything but houses they can slap up in a hurry. It's been this way here for the past 8 years.
- termites.
- all manner of wood boring insects
Absolutely ! Insurance company sent an appraiser to our place 4 years ago trying to drop our coverage after 25 years and he assessed our (open frame, uninsulated) 5000 square foot x 16' wall hangar alone for $458,000 CDN to replace if it burnt to the ground.. and concrete don't burn.Better get that is writing. Concrete alone averages about 8.00 a square foot.
Have you looked into the curved building's a buddy of mine put his own up with family helping. He put up a stem wall to raise up the building to give him more space on the side's. Which seem to be the problem with those type of building's. Or if you search on line you can find building's that have been ordered and are lying in fields. Cheap but shipping can push up the pric.
I did the metal company said he cannot put it up unless it was re-engineered again due to insurance issues, and that usually don’t touch them. Biggest problem is I don’t live there full time and work much overtime so I’m at the mercy of the builder. I just need to research more and get more quotes. And concrete alone is a large cost of this project also with lumber.Have you looked into the curved building's a buddy of mine put his own up with family helping. He put up a stem wall to raise up the building to give him more space on the side's. Which seem to be the problem with those type of building's. Or if you search on line you can find building's that have been ordered and are lying in fields. Cheap but shipping can push up the pric.
Same here. 36X48 all steel with wood frame. Who wants to be bothered with phone calls when you're in the shop anyway?Outlawd is right. My garage is a wood frame pole barn type building with sheet metal roofing and siding panels. Cell service is bad. I have to step outside to talk. But, its no big deal to me.
Pictures? I just had floor poured last week. 85K that’s good with everything you have done. Who build your pole barn?I am finishing up my garage build now. I went with a pole barn, steel over wood. I hung a steel ceiling in it. Ceiling's 16ft high, having blow in insulation done on top. Running 2x4 up walls between the posts, putting roll out R16 between boards covering with drywall. I would never work in an unfinished garage. So far, floor is concrete and painted polyasperic, ceiling is almost finished, LED 8 ft lights in, all wiring is done and power connected to the shop.
It's 60x64x16, so far I have nearly 85k in it. And it's not done. It'll be a few years before I can afford to do my rooms inside. Economy and prices suck.
That bubble insulation lasts about 10-15 years. I have that in my.shop. The tape used degrades, however, and you'll start to see bits come off the wall after a time. I intend to have foam used on the sidewalls this Fall, to replace that bubble stuff.I'm planning on:
- Metal
- 14' wall
- 40' wide minimum
- 60' long
- No electric
- No plumbing
- termites.
