When you want a 440, you have to work for it
Moparnocar
11:03 AM
Mahtomedi
Found a 77 RV w a 440. Made a deal for it, but I had to pull it.. alone. My picker broke through the boards I had, into dirt. Had to use minivan to pull it out of the hole! And into the back of a caravan
I'm amazed at what they are capable of, other than a valve springs and lifters change, a cam swap, a carburetor...
Then bolt on nitrous and spray!
THAT was productive. To go one BIG step UP? Swap in a cheap blow through carb and single turbocharger and now you have 650+ ft lbs torque and 527 horsepower with plenty of time for additional tuning.
You're earning that one man, and so is the minivan! 440'
Sheeeiiiit.......looks like you got off easy! I have one I'm getting ready to yank from a chassis like that, straight out the front.
Much quicker than the last one I got!
Ha, ha: Yep, I pulled a couple of 8V92's out of a boat a few years ago, that was a bit tricky too.
I hope you grabbed the kickdown rod - same as 71-72 on a lot of them.
No I didn't, but going back for the tranny in a few days Anything special about the RV 440s? It's car a standard water pump on it, and a weird bracket, looks like AC, had a thermoquad on it, I'll probably be selling that, the exhaust manifolds, etc
