steve from staten island
- 9:55 AM
- Sep 24, 2012
- staten island,ny
I need my suspicions confirmed
The safety lifted on the furnace today
The unit was running and the water temp was were it should be but the pressure was to high
I drained some water brought the pressure down and shut off the water supply
Since I have a indirect hot water heater I gave the unit about two hours to see if the pressure rose, indicating a leak in the heater coil
No raise in pressure
Opened up supply valve and another two hours later pressure is still ok
The only thing I can think of is the expansion tank is saturated with water
I know the old style tanks were the best
Drain at the start of season and you were good to go
This is a bladder type of tank
It’s not close to new and I know the bladder can go
If I have a repeat of this problem I thinking expansion tank
Thoughts are appreciated
