—-I have only made 4 passes with this motor so far if I can run 10.50s that would be great! Going to hopefully do test this weekend. Question about test I can run just one out feed line from regulator to gas can or should I do both?
Checking with both sides would be the proper way. You could start by checking the one side and see what you flow at. May not have to check both.
