Indicators both flash
Durandal25
11:42 AM
Texas
Team,
So I have not dug too deep into this issue yet, but when I use the turn signals- right or left- they both flash. I did add a new brake switch and may have wired it backwards, but what do you think? The brake light works fine when I press the pedal….
you may have a ground issue. Or your turn signal switch is wacked
So checked the brake light switch and no effect on the lights. Its interesting. Going through my check list of stuff again tonight, and making sure all the dash bezels are seated and all the dash cluster screws are in good....metal to metal. Horn works fine too, so the column ground is good.
Anywhere but isn't there a ground of some sort at each light?
There is, but if the ground were not connected at those locations, then the lights would not illuminate.
I have solved the puzzle . Two new blinkers were required
Good that you corrected it.
However on the ground issue, they can be connected but not good enough to support the needed return path for the elec flow. A poor ground can cause a resistive path so the return power finds an easier path usually causing other lights to blink, light dimmly etc.
