tmaleck
I use KBR high temp. They specialize in that stuff.
Cant find KBR. Did you mean KBS?I use KBR high temp. They specialize in that stuff.
yes. I wasn't sure I had it rightCant find KBR. Did you mean KBS?
Looks good! Brushed, or gunned?
How did you prep the block?
Did you prime the engine block?
Looks great.
Used the same with great results.Epoxy primer and eastwood hemi orange. I’ve used it on a few engines now.
View attachment 1146473 View attachment 1146474
That look sweet. You used their primer? Sprayed everything or brush?Used the same with great results.
View attachment 1149889 View attachment 1149890 View attachment 1149891
I just used etching primer under the Eastwood ceramic and it looks great and flowed out very well.
I ask because people online said Eastwood is too thin? That’s with your gun or a spray can you can buy?
thanks
my block is being repainted. It’s been wire brushed and as best I can removed all loose paint. I don’t think I would use self etch if some paint is still on the block?
