Ironbuilt
- 11:59 PM
- Jul 1, 2017
- North Carolina
I want one!!View attachment 1150318
Don't own it. But I did help design it.
BAE Systems FMTV 10 Ton 6x6 wreckerI want one!!
The 4x4 troop carrier did. Though I don'tCome with .50 cal or is that extra??
Really like the fender mounted mirror
Fender mirror on pass side too, not in picture: pretty solid truck considering: rockers solid, rear cab corners no rust, doors lower fenders normal rust, top front of cab solid, surface rust only: chop & weld not THAT great. Unable to open doors to see floors etc. 4x4 4spd truckReally like the fender mounted mirror
on the driver's side. That thing is a tank!
Hi Oldbee, got a crazy problem I've tried to fix with no luck. 2006 Dakota 4×4 4.7 mag. It's a steering issue while turning slightly at speed my steering wheel oscillates. Very concerning!! Any idea?Trucks? You talkin like Ironbuilt(& others have)? Worked on 'em for over 30yrs. Owned a couple, but not Mopars; love them though.
Buttin' in again, please forgive.Hi Oldbee, got a crazy problem I've tried to fix with no luck. 2006 Dakota 4×4 4.7 mag. It's a steering issue while turning slightly at speed my steering wheel oscillates. Very concerning!! Any idea?
Thanks for butting in. This issue is racking my brain. While driving like I said, steering wheel oscillates and very uncomfortable. I was thinking maybe steering pump. I've tried bleeding it manually. Definitely afraid to let my wife drive it. Thanks for the advice I will do just that.Buttin' in again, please forgive.
I'd check for loose bearings, bent
wheel, or a bad tire. I would lean
towards a bad tire. Try a tire rotation.
