1963JAM
- 8:54 AM
- Sep 5, 2021
- Worcester County Massachusetts
I'll take a look. Didn't think of that. Thankshow's your motor and transmission mounts?
Have to wonder if bad engine/trans mounts would make a constant vibration? What I have is a vibration that comes and goes with a rhythm.how's your motor and transmission mounts?
Mine had the vibration at the same engine speed whether it was in First, Second, or Drive. I figured that ruled out the drive shaft.Also it could be as you stated a Harmonic imbalance which also could be caused by a drive shaft also being out of balance. I'd check that also...cr8crshr/Bill
Haven’t done anything to engine or drivetrain. Bought car as is this past August, thought vibration was tire balance. Now I’m on the hunt.How long have you owned it, what do you know about the engine, and what was the last thing you did
to it before it started?
No tranny work.Dropping all the accessory belts for a short driveway test of reving the engine is also a good idea to elemental any possibility with a bad accessory pulley or similar. Have you had any transmission work done in recent time? New torque converter?
