I was keeping it under wraps during its bad boy nights in the civilian theater of operations, but as they say, the cat's got to come out of the bag at some time. 2990 Lbs WITHOUT me in it.
All metal/s, no fiberglass, carbon fiber, hence the Fullmetaljacket identification code. I want to achieve 2800 Lbs with all metal parts to reflect the fiberglass '65 AFX scale numbers. This practice can be applied to any other car with careful eyes as far where, why and how.
For example, GTX John here has achieved some amazing numbers with is '70 GTX. Lost pounds using a group of hand selected OEM parts and bolts. He probably has a fiberglass bumper, but nothing more than that. Different supply houses differed in the weight of their parts by design or metal density, so only a mad scientist could dive down that rabbit hole. GTX John has come down to 3100 Lbs or so.
3100 Lbs with dana 60 and 400 with "stock" cast iron intake manifold.
Stock Cam/9:1 stock compression/Thermoquad = 10.9 @ 119 when no one
at NHRA is watching.
'73 Roadrunner with the factory weird suspension/Strange Frame K Member/J
Torsion bars that weighs a ton.  It will be at all West Coast NHRA National races if anyone would like a tour of it and the tricks.  Most of them are not Cheap!
No Fiberglass Bumpers = I would get thrown out forever.
I did put glass bumpers front and back on My Turbo Buick to get it light enough
to set a National Record for ONE race and then took them off before we got caught!
There is a lot of weight that can be remove and concealed in bumper area on the Newer cars without it being obvious.  Even the earlier cars have very heavy brackets that can be redone with a nice weight saving.  Cheap Hint:  If there are two bumper brackets on both sides on your cars - Lose the heavier one and put the other on a diet or fab a light one. If you do not bump into stuff a lot!.
30 years ago I would go out the the Garage after the Kids went to bed and put
the car on Jack Stands and Not go to Sleep until I remove 2 Lbs. every night!
My 71 Demon with a full cage/working windows/Full cage and extra 60 lbs of
frame support/torque boxes/Connectors  and extra crossmembers in just over 2700Lb. Wet
Another Hint: Assorted Grinders /Scrapers and a Hobby Torch and a LOT
of Elbow Grease!
Check it out :  Google John Irving Drag Racer
                     and Mopar Garage Last week for my boys Demon
