The hose to the air cleaner will have a light vacuum on it at idle so the volume through isn’t so high.
Sorry. Frustrating so stay with it. Another poke at it. How new is your fuel????@pnora I also sealed off the vent where PCV goes on one of the valve covers and couldn’t feel any vacuum on the other valve cover opening.
Doesn't really matter where you start, just get it to temp and adjust for max vacuum.
Stop chasing "rich smell". It's going to have un-burned hydrocarbons exiting the exhaust with a cam that size.
It will lean stall long before you get the exhaust to not smell like fuel.
I been thinking quite a bit on the edelbrock idle mixture screws. I know that the somewhat norm is to start with them 1 1/2 turns out from closed but in my pondering wouldn’t that be too far out when running as a dual 4 setup? It makes sense to me that you would start with them out half of 1 1/2 turns with two carbs 3/4 turn out and tune from there.
Do the 1-1/2 turn out on both carbs for a base. More than likely you'll find that the front and rear carb will be set the same when all is tuned in. I used a vacuum guage and tach when setting mine. Did the rear for highest vacuum and rpm then the front. Went back over them again and all is well.
When initially tuning these carbs I had them setup with the progressive linkage and I noticed a high temperature with the front four cylinders. (Using a IR temp gun) This was telling me there was a lean condition with the front carb. After opening the front throttle plate just a little (using the idle stop screw) the front cylinders returned to a normal temperature. I changed the linkage to one to one and have both front and rear carb throttle plates set the same at idle.
Don't forget that having proper timing set is very important when tuning any carb whether one or two carbs. You might have to go back and forth a couple of times between the timing and carbs before it all gets dialed in. You'll get it.
Well![]()
Spark plugs pics, you said they were cleaner.
Been fighting same thing with my xram with Holleys. Had worn throttle shafts rebushed and opened secondaries some, helped some. To cold to play in garage with door open now.
I am waiting for this to be solved but 8" of vacuum, race type manifold and cam, 11.5 compression why do you even have dual points and a vacuum advance? None of this sounds like a street setup. With such low vacuum to signal to these carbs it is hard to believe your rich. But with fuel in oil are you sure your rings are good?
Fran,
What kind of pics you wanting? From Kryslerkid if so I agree! If from me I have plenty to post![]()
