biomedtechguy
Accelerati Rapidus Maximus
- 12:38 AM
- Mar 28, 2014
- South Louisiana
Andy said he liked the 4.25 stroke. I can see quite a difference in piston speed between the two, but then again, I'm not likely to be wringing it's neck like a high compression, radically cammed 440 would.
I figured I'd put the question out on the forum. I'm getting to the point of paying for my rotating assembly. Molnar forged stroker crank, same price for a 451 (4.50 bore x 4.25 stroke) or a 4.5" stroke (572)
No clearancing required for either w/my Bill Mitchell block.
The builder recommends single line external oil pump pickup either way, although the 4.25 wouldn't require it. 7.100 rods/2.200 journal. Diamond pistons as Ross is way past the delivery date they've promised.
My main goal? 700 ft lbs torque across as wide an RPM spread as reasonable. Let the horsepower fall where it will, although 6XX is expected. 3x2 Holley carbs on the ModMan intake.
Thanks...
Thanks...
