You can always mount the white letters inside.Thanks everyone.....appreciate it
Do the cooper's have a black wall side? Not sure how the lettering will look
You are lucky.. Lots of people have browning issues with the outer most part of the letters.I’ve had BFGs for about eight years. No browning at all.
Any issue rubbing?I'm very happy with my Mickey Thompsons Sportsman S/T's. They seem to handle track use and street use well, and aren't wearing down as fast as I'd expect them to.
Here are the sizes on my 69' Bee
Front Rim: 15x8, 4.5 bs
Front Tire: 245/60R15
Rear Rim: 15x10, 5.5 bs
Rear Tire: 295/50R15
View attachment 1240642 View attachment 1240643
What size tires and rims?
Pretty good endorsement, given that Dennis has gone cross-country on a set of those...Cooper Cobra.
What did you do that a 4.5" backspace wheel doesn't rub the upper control arm?I'm very happy with my Mickey Thompsons Sportsman S/T's. They seem to handle track use and street use well, and aren't wearing down as fast as I'd expect them to.
15”. 295/50 15’s. Think they are 8” rims. Came mounted and balanced from Summit as pictured minus the dime store trim rings. 69 Coronet. Did put a spacer on the drivers side only (thanks Kern) as the inside wall would kiss the leafs when pushed hard. Safe in heavy rain/freeway.What size tires and rims?
on my '67 i have Nitto tires Z rating 225/45ZR17 FRONT 255/45ZR18 REAR. Rides and handles excellent. have 390 HP. says NT555G2 on label66 Satellite -
500 plus inches under the hood
3:73 rear
Looking for a tire that rides well, handles "OK" in the corners (as well as expected), gets a decent amount of traction on the road/street. Not looking for a bias ply or a dedicated "slick type" street tire.
Really leaning heavily towards Cooper Cobras - but just thought I would check if there is anything else I should look at.
Any issue rubbing?
Summit doesn't have the 15x8 with 4.5bs till May, they only have the 4.0 BS if those will work on a 69 Charger.
Thank You
Different front hub and rotor assembly?
When 15x7 Mopar rally wheels came out Chrysler engineers said they wouldn't fit early cars. I bought a pair to test fit on my1964 Plymouth, there wasn't much room cycling through full jounce and rebound but they cleared.
For entertainment purposes I bolted late Charger 17x7 4.9 bs wheels on my 64. Strange looking.
