Charlie Brown
- 10:50 PM
- May 23, 2021
- Vars, Ontario, Canada
Car in question is a 64 Polara. Pretty sure there was never any structural damage. I've installed Moog K 7103 off set bushings at both control arm locations (total 4 bushings).
New lower control bushings etc.
I have a Blue Point (Snap on) bubble caster / camber gauge with turntables. Never used one before, but I think I'm using it correctly.
Best readings I can get is drivers side neg 1/4 degree camber and pos. 1 3/8 degrees caster.
On the passenger side the best I can get is 1/4 degree neg camber and 5/8 degrees pos caster.
With the Moog offset bushings I should be getting way more caster. I installed bushings as per attached link.
https://www.forbbodiesonly.com/moparforum/threads/suspension-upgrade.213487/#post-911826643 See post #7
I've spent hours on this and it's driving me bonkers. Comments welcomed.
Charlie
Charlie
