- 2:29 PM
- Oct 16, 2014
- Salisbury, Vermont
I will read and heed my friends.
I wouldn't worry about it. But, if the center of the gasket is not doing anything, cut it out with a box cutter. If you didn't and it is installed, I wouldn't worry about it. I think there is essentially ZERO chance it gets sucked in to the intake.Worried about the carb base gasket that has the four big holes, one for each barrel, being above the 1" spacer plate wont the engine suck that gasket into the intake? Nothing supporting the center of that gasket. Hmmm....advice please....
Well, it's a single plane intake so no supporting structure in the middle under the carb.I wouldn't worry about it. But, if the center of the gasket is not doing anything, cut it out with a box cutter. If you didn't and it is installed, I wouldn't worry about it. I think there is essentially ZERO chance it gets sucked in to the intake.
I get it. But I don't think it can get sucked into the manifold.Well, it's a single plane intake so no supporting structure in the middle under the carb.
I think i will do that before i hook everything up. Might pop by the hardware store too and pick up four fancy bolts to hold the carb down'I get it. But I don't think it can get sucked into the manifold.
If you prefer, unbolt the carb and cut it out, since the center part of the carb gasket is doing nothing...
Can ya post a pic? Been years since I messed with any kind of a fuel cell but I'm thinking that you can remove the nipple and stick in a 90 but a pic would help clear up any doubt....Question: On the A/N fuel tank fittings, 8AN, they're male nipples sticking up from the tank surface. I need them to be 90*. So, do I get a 90* fitting and attach it to that male nipple or pull the nipple and screw in a 90* in its place? I want to 90* towards the front of the car, then braided fuel line across the top of the tank, through a chip wood carpet covered panel and then attach to a rubber fuel line between there and the 3/8" aluminum fuel line hugging the frame up to the engine bay.
