joe smith
When your compressor runs, the air is produces is hot and will retain moisture, as the air cools it will release the moisture... A cheap way to make a " dryer" is to wrap the exit pipe around the top of your shop and install a few " T's" to have some drops with a twist drain at the bottom....A bud that has done a lot of blasting and painting suggested I reroute my compressor regulator/filter at least 10 feet away from the compressor as I’ve dealt with moisture accumulation. Something I didn’t know; but haven’t done this yet..
If your not in a high humidity area it works very well....
