Joe Palmer
Yes, and no I didnt check. I put a new carb on the old spacer gasket. Timing is currently 12 degrees at idle (vacuum disconnected) and 32 degrees roughly by 2900 RPM....As you posted, the issue was way advanced timing (aside from a bad carb gasket)? Curious, did you do a vacuum leak check around the carb earlier? What do you have the timing set at now? Thanks
