Do you use gaskets with exhaust manifolds on a 440?
Trench
3:18 AM
nova scotia
My motor is almost done and I do intend on using exhaust gaskets but i did notice the factory manual says they are not needed. What does the B Body community do? Gaskets, no gaskets, or gaskets and sealer like copper rtv?
I'm very interested to see what the opinions are here, and as always thanks in advance!
If the manifolds are straight and not warped, no gaskets. If warped then chuck the manifolds or have them milled by engine shop. Confirm with a straight edge. If headers then use copper gaskets.
My frank answer is I've done about everything depending on the engine and exhaust. Nothing, copper rtv only, every kind of gasket, gasket plus copper rtv...
I'll add that in circumstances where I use a gasket in that location, I trim the spans of bridge material between the ports so they're not visible; improves appearance and access.
There's no reason to re-install a warped manifold - fix it beforehand, as already mentioned. On the drag car, I use the hi-temp silicone instead of a gasket, but if it had to come apart often, I'd use a gasket.
I’m not sure how much horsepower headers add but... I remember a few guys cutting half a second off the 1/4 ET.
They are cast and will clean very easily on a large belt sander like heads cleaned up on.
Done all that too many times
Stock cast manifolds, use 440 motorhome gaskets. Trim up if you like.
Just bought a system from accurate exhaust, and they told me "make sure my manifolds were flat, and don't use gaskets, that's what cracks cast iron manifolds." So I just did what they said, and no leaks.
