71GTXFY1
- 10:49 AM
- Dec 13, 2020
- Logan Martin Lake, AL
Hello all. I've been reading with great interest accounts of y'all converting your cars to FI. I've decided to do the same, buying parts in anticipation of doing the work this fall/winter. I've read a lot of info but haven't read the answer to my question today. For those of you with 1971 (and I must assume 72-74) who have made the switch, have any of you successfully used the fuel tank emissions vent hardline (on the pass inner fender) for the system fuel return-to-tank line?
I am going to install the 6-Barrel system (39610 Go EFI Tri-Power 600HP System - FiTech Fuel Injection)
Using the force fuel pump/sump (50004 Force Fuel System - FiTech Fuel Injection) mounted probably where the stock washer fluid bottle is. My plan is to use the stock mechanical fuel pump to pump gas to the fuel pump/sump assy.
If any of you report problems with my proposal of using the tank emissions vent for the return line, I will likely plumb a braded steel/AN fitting return line to (an also yet to install port on) the fuel tank like this one (51002Black Stainless Steel Hose Kit, 20ft w/ 10 Micron Filter and Check Valve - FiTech Fuel Injection).
Nice work to all of you who have posted progress/completion stories.
