70chall440
Nice work, while looking at the pics I was reminded of a video I saw on youtube wherein a builder puts silicon bronze in all those seams, it flows really well and can be painted over or left visible.
Thank you! I like that the silicone bronze has way lower heat input (like 1/2 with .045 filler), blends easy with a DA, doesn’t shrink nearly the same as 70S, and planishes very nicely. You just have to lay it over a really good series of 70S tacks. I’m almost certainly going to do that on the flat seams for the corner extensions where the cowl joins the pillars.Nice work, while looking at the pics I was reminded of a video I saw on youtube wherein a builder puts silicon bronze in all those seams, it flows really well and can be painted over or left visible.
Top notch as always David!Working to eliminate another lead filler line, and extend the upper cowl to meet the pillar.
One side:
The other side, and how I made the patch.
From there, it's just finely fitting the roughed in patch, and then more welding and blending, and maybe a smidge of planishing to deal with weld shrinkage.
David
Thank you. Quick progress like this is very motivational.Super work!
GREAT DEVOTED WORK THERE!!! Plus, i LOVE your statement.....'AMD minitubbed inners are handier than pockets on a shirt'. Love it!!One wheelhouse roughly fit. The AMD minitubbed inners are handier than pockets on a shirt.
3/8” gap to the rail came out as designed. Pretty cool to see this work out.
Other side is hacked and ready for fitting.
I still have to eliminate the outer hump, and I won’t fine fit these and lock them in until I fit the quarters and rest of the rear sheetmetal.
David
Copy, paste.
I picked up fresh AMD wheelhouses, and I think I’m going to take a break from the cowl and turn my attention to the rear of the car for a bit.
David
As usual, fine work David!Initial repairs on the window channel went pretty well.
Copper backers, all day.
The old steel spits and sputters, and I use a mix of TIG and MIG depending on how it's behaving.
I did a little more blending, but this piece is ready for a quarter panel.
Also, I hit the interior of the rear panel with the DA and a pretty liberal amount of rust converter. I'll scuff this again and seal it with my favorite e-coat primer.
It's nice to be able to do these small repairs without completely replacing a series of panels.
David
Thank you. If I've done it right, it'll just look like a 70 charger to most folks. Only y'all here and a few others will see and know the details.Nice work!! To bad a lot of that crafty work will never be seen by most.
