I wouldn't use an adapter get the right manifold.
Excellent! Yes regarding the weight of the original intake, it about tipped me into the engine compartment when I was trying to reinstall it. That shizz is heavy!!That intake is a decent piece. It flows similar to stock and weighs half as much.
There was no sticker.
So I'll try my hand at some answers Gary...So I have some questions fellas:
You must be a muppet!!!5) why did it take all Saturday to get the simplest of tasks done on these two naughty naughty vehicles? Anyone else have days like these? Or is it just me being a muppet?
When you run your wipers, do they go quite far and perhaps even hit the trim on the side of the windshield? I suspect they are merely put on clocked a bit in the wrong direction. If this is the case: With them parked and off, simply pop off each wiper arm and put it back on the splines where you'd like to see it. To pop them off without a special wiper arm tool, I pull up on the spring loaded arm, while at the same time pry gently on the other side with a good, angled pry bar. I always put a block of wood or other protection down for the pry bar too.3) why do my wipers park themselves like this?
I am not familiar with how the Monaco fuse panel works - not sure if it is the same as my 73, so I have no magic fixes here. Maybe a bent up paper clip or a binder clip to hold it?2) the tab holding the fuse panel upside the dash broke when I took it off, anyone have a good idea how to fix it back up there?
This is a terrible picture - I couldn't find one any better...1) what is that white connector
4) my alternator gauge has never worked. It’s sat in this spot and hasn’t moved. How would it work again?
Fred!I ordered some plugs for the unused ports in the manifold…$16 from Amazon
And capped off the unused ports. I ran out of light and to be honest, I ran out of energy too, so here’s the intake ready to go back on, I just have to finish making my thermostat housing gasket and it’s ready to roll...
Adam text me Thursday evening, with pictures of the Thermoquad just before it’s acid bath…
View attachment 1357214View attachment 1357215View attachment 1357216
In you go, you dirty bastard!! I can’t wait to post pics of the carb looking all spiffy and fresh.
That’s all for now fellas, but as I paused my Hunter box set to post this, I look up and what do I see….
A fire department spec four door Monaco. Damn I love these cars. Am I sick?
