- 7:49 AM
- Apr 13, 2012
- Granite Bay CA
Hello,
I'm closing in on the point to start the car after a rebuild. Once I get it up and running, I'll need to do some tuning since I changed a few things while the car was apart.
The combination is as follows:
1970 Charger. 440 based 495 with 9.8 compression. Edelbrock heads, Lunati solid flat tappet cam,2" headers, 3" exhaust, Demon 850 Vacuum secondary 4 barrel with 85 primary jets, 92 secondaries. 6.5 power valve. 3 psi of fuel pressure at idle, 7 psi at WOT. Carter fuel pump registered 11 psi at idle before I put in an Aeromotive bypass regulator. There is no vapor lock and the car runs great in all temperatures.
The problem that I have had is that under hard deceleration, the engine tends to stall. The same happens when descending a steep hill. I suspect a fuel level issue. This carburetor has glass sights in the primary bowls and on level ground, the fuel is right in the middle of the glass like it is supposed to be.
I don't recall if the stalling issue has only happened when I'm low on fuel where the fuel pickup could be uncovered but I don't think that is the cause.
Any suggestions as to where else I should look?
