I was able to get some time in on the car today. I dropped the engine/trans back out as I need to work in the area around the trans mount/torsion bar x-member area. Markings on the collectors are where the O-2 bungs go. The new trans mount got its holes punched in. I enlarged the existing holes in the original x-member area that will get re-used for new thru tubes that the trans mount horizontal bolts go through. From there I marked out material to finish off the spots not hit yet for the x-member reinforcing. It's way easier to do when standing as opposed to laying on the creeper. Tomorrow will be cut, weld and grind day to get that area finished off. From there I'll hit the back of the car to tackle the spring relocation. Due to where the shackle sleeves will be in the frame rail, I'll need to make cuts in the trunk floor so I can get the drill motor and hole saw in to make the sleeve holes in the frame. No big deal as I planned on re-doing that area so I can use an off the shelf early Stang fuel tank, hopefully the 22 gal one, which will fit between the rails and be EFI ready. After all of that is squared away I'll get onto the passenger compartment floor re-do's and fill in. I went to Santa Maria on Monday and got a sheet of 20ga cold rolled so I now have material to use on the floor. The original stuff I removed was 20 also. This will give me a chance to re-learn how to use my metal forming machines and skills.
